Ga door naar hoofdinhoud
Dopo Double Power 7 Motherboard Replacement
Wat je nodig hebt
  1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove any static tape covering the motherboard.
  6. Dopo Double Power 7 Motherboard Replacement: stap 6, afbeelding 1 van 2 Dopo Double Power 7 Motherboard Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
  7. Dopo Double Power 7 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
  8. Dopo Double Power 7 Motherboard Replacement: stap 8, afbeelding 1 van 2 Dopo Double Power 7 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Using wire cutters, cut the red, black, and grays wires.
    • The motherboard can now be removed
    • Leave enough wire to be re-soldered back if possible.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
mike pelosi
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-2, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 501
