Ga door naar hoofdinhoud
Dopo Double Power 7 Camera Replacement
Wat je nodig hebt
  1. Dopo Double Power 7 Camera Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Camera Replacement: stap 2, afbeelding 1 van 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Camera Replacement: stap 3, afbeelding 1 van 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Camera Replacement: stap 4, afbeelding 1 van 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Camera Replacement, Camera: stap 5, afbeelding 1 van 1
    • Remove any black static tape that may be covering the motherboard.
  6. Dopo Double Power 7 Camera Replacement: stap 6, afbeelding 1 van 2 Dopo Double Power 7 Camera Replacement: stap 6, afbeelding 2 van 2
    • The camera is taped in place.
    • Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
    • Our cable had previously been cut but yours can be disconnected by lifting up on the black section of the socket, as shown by the arrow, and pulling the cable out.
    • Simply, pull back the tape and remove the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
mike pelosi
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-2, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 157
