Ga door naar hoofdinhoud
Dopo Double Power 7 Battery Replacement
Wat je nodig hebt
  1. Dopo Double Power 7 Battery Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Battery Replacement: stap 3, afbeelding 1 van 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Battery Replacement: stap 4, afbeelding 1 van 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Cut only the red and black wires attaching the battery to the motherboard.
    • Be sure to remove any remaining wire attached to the motherboard.
  6. Dopo Double Power 7 Battery Replacement: stap 6, afbeelding 1 van 1
    • Using a metal spudger, carefully pry the battery away from the digitizer.
    • Be careful to not damage the battery. This could result in injury.
  7. Dopo Double Power 7 Battery Replacement: stap 7, afbeelding 1 van 1
    • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
    • Twist the strands of the spliced wire together.
    • Using a soldering iron, apply heat to one bare wire connections you have just made.
    • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
    • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
    • Repeat this process with the other wire.
    • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
    • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
mike pelosi
682 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-2, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,019
