Wat je nodig hebt
Remove the green board with the controls first.
DON'T USE FORCE, it should get lose easily. Don't bend the cables too much.
Remove the cable from the control board
Lift the display off, don't bed the cable too much.
Open the connector of the cable carefully. Don't scratch the board and don't use too much force. Ideally, use a plastic spudger of the ifixit-kit
The display got removed, not just fit the new display in reveresed order.
Follow the steps in reverse order to reassemble.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
