Ga door naar hoofdinhoud
Disconnecting the Battery
Alleen vereisten
Deze gids is alleen bedoeld voor beginners! Deze gids maakt deel uit van een andere procedure en is niet bedoeld om alleen te worden gebruikt.
Wat je nodig hebt
  1. Disconnecting the Battery, Bottom Cover: stap 1, afbeelding 1 van 2 Disconnecting the Battery, Bottom Cover: stap 1, afbeelding 2 van 2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Disconnecting the Battery: stap 2, afbeelding 1 van 3 Disconnecting the Battery: stap 2, afbeelding 2 van 3 Disconnecting the Battery: stap 2, afbeelding 3 van 3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Disconnecting the Battery, Disconnecting the Battery: stap 3, afbeelding 1 van 3 Disconnecting the Battery, Disconnecting the Battery: stap 3, afbeelding 2 van 3 Disconnecting the Battery, Disconnecting the Battery: stap 3, afbeelding 3 van 3
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Disconnecting the Battery: stap 4, afbeelding 1 van 2 Disconnecting the Battery: stap 4, afbeelding 2 van 2
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
Conclusie
Bijgevoegde documenten
Henry Bryant
340 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 90
