Ga door naar hoofdinhoud
Disconnecting Microphone from Logitech Pro 9000 Motherboard
Wat je nodig hebt
  1. Disconnecting Microphone from Logitech Pro 9000 Motherboard, Front and Back Cover: stap 1, afbeelding 1 van 2 Disconnecting Microphone from Logitech Pro 9000 Motherboard, Front and Back Cover: stap 1, afbeelding 2 van 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Disconnecting Microphone from Logitech Pro 9000 Motherboard: stap 2, afbeelding 1 van 2 Disconnecting Microphone from Logitech Pro 9000 Motherboard: stap 2, afbeelding 2 van 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Disconnecting Microphone from Logitech Pro 9000 Motherboard, Microphone Connection: stap 3, afbeelding 1 van 2 Disconnecting Microphone from Logitech Pro 9000 Motherboard, Microphone Connection: stap 3, afbeelding 2 van 2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
Conclusie
Timothy Forrest
19 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-34, Amido Spring 2013 Lid van Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Leden
16 handleidingen geschreven
1Gids Commentaar
This guide doesn’t show a motherboard and is a copy of this other guide (for a webcam):
Logitech Webcam Pro 9000 Microphone Replacement
Maximilian Cohan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 1,974
