Ga door naar hoofdinhoud
Disconnecting Garmin Nuvi 680 Screen Wiring
Wat je nodig hebt
  1. Disconnecting Garmin Nuvi 680 Screen Wiring, Outer Case: stap 1, afbeelding 1 van 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Disconnecting Garmin Nuvi 680 Screen Wiring: stap 2, afbeelding 1 van 1
    • Remove the antenna cover.
  3. Disconnecting Garmin Nuvi 680 Screen Wiring: stap 3, afbeelding 1 van 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Disconnecting Garmin Nuvi 680 Screen Wiring: stap 4, afbeelding 1 van 2 Disconnecting Garmin Nuvi 680 Screen Wiring: stap 4, afbeelding 2 van 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Disconnecting Garmin Nuvi 680 Screen Wiring: stap 5, afbeelding 1 van 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Disconnecting Garmin Nuvi 680 Screen Wiring: stap 6, afbeelding 1 van 2 Disconnecting Garmin Nuvi 680 Screen Wiring: stap 6, afbeelding 2 van 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Disconnecting Garmin Nuvi 680 Screen Wiring, Antenna: stap 7, afbeelding 1 van 2 Disconnecting Garmin Nuvi 680 Screen Wiring, Antenna: stap 7, afbeelding 2 van 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Disconnecting Garmin Nuvi 680 Screen Wiring, Screen Wiring: stap 8, afbeelding 1 van 1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Disconnecting Garmin Nuvi 680 Screen Wiring: stap 9, afbeelding 1 van 2 Disconnecting Garmin Nuvi 680 Screen Wiring: stap 9, afbeelding 2 van 2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Allen Pasch
261 Reputatie
1 Handleiding geschreven
Cal Poly, Team 5-22, Amido Winter 2011 Lid van Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,466
