Ga door naar hoofdinhoud
Disassembling the Nokia 6300
Wat je nodig hebt
  1. Disassembling the Nokia 6300, Rear Cover: stap 1, afbeelding 1 van 1
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: stap 2, afbeelding 1 van 2 Disassembling the Nokia 6300: stap 2, afbeelding 2 van 2
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: stap 3, afbeelding 1 van 1
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: stap 4, afbeelding 1 van 1
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: stap 5, afbeelding 1 van 1
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: stap 6, afbeelding 1 van 3 Disassembling the Nokia 6300: stap 6, afbeelding 2 van 3 Disassembling the Nokia 6300: stap 6, afbeelding 3 van 3
    • There's your phone!
Conclusie
20 andere personen hebben deze handleiding voltooid.
LucasJV
741 Reputatie
3 handleidingen geschreven
1Gids Commentaar
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 56
Altijd: 24,744
