Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The Mobius ActionCam is a small, durable video recorder often used as a helmet or dash camera.
The disassembly is very simple and individual components are easy to replace.
Wat je nodig hebt
Remove the lens cap.
Remove the SD card by pressing down on the card until you hear a click, then releasing.
Locate the camera module.
Grab the sides of the camera module and gently pull upwards to free it from the case.
Use your finger to pull up the black tab on the rear of the ribbon cable connector.
Slide the ribbon cable out of the connector to remove the camera module.
3 andere personen hebben deze handleiding voltooid.
