Inleiding
Multiple parts can easily break during disassembly. Proceed slowly with caution to avoid problems.
Wat je nodig hebt
Anti-slip pads cover three screws that hold the device together. Pry off the pads to access the screws.
Remove the three screws.
Once the three screws are removed, the device is ready for disassembly.
Push up on the rear flap while holding down on the rest of the body. This will open a small gap.
Insert the plastic opening tool in the gap and begin prying on the corner.
Continue to pry around the body of the case. Separate both sides of the case with this method.
13 andere personen hebben deze handleiding voltooid.
