Ga door naar hoofdinhoud
Disassembling the HP Pavilion tx2500 Bezel
Wat je nodig hebt
  1. Disassembling the HP Pavilion tx2500 Bezel, Screen Rotator: stap 1, afbeelding 1 van 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. Disassembling the HP Pavilion tx2500 Bezel: stap 2, afbeelding 1 van 2 Disassembling the HP Pavilion tx2500 Bezel: stap 2, afbeelding 2 van 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. Disassembling the HP Pavilion tx2500 Bezel: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. Disassembling the HP Pavilion tx2500 Bezel: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. Disassembling the HP Pavilion tx2500 Bezel: stap 5, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. Disassembling the HP Pavilion tx2500 Bezel: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. Disassembling the HP Pavilion tx2500 Bezel: stap 7, afbeelding 1 van 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. Disassembling the HP Pavilion tx2500 Bezel: stap 8, afbeelding 1 van 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. Disassembling the HP Pavilion tx2500 Bezel: stap 9, afbeelding 1 van 2 Disassembling the HP Pavilion tx2500 Bezel: stap 9, afbeelding 2 van 2
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. Disassembling the HP Pavilion tx2500 Bezel: stap 10, afbeelding 1 van 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. Disassembling the HP Pavilion tx2500 Bezel: stap 11, afbeelding 1 van 2 Disassembling the HP Pavilion tx2500 Bezel: stap 11, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. Disassembling the HP Pavilion tx2500 Bezel: stap 12, afbeelding 1 van 1
    • Gently lift up and remove the screen.
  13. Disassembling the HP Pavilion tx2500 Bezel, Bezel: stap 13, afbeelding 1 van 3 Disassembling the HP Pavilion tx2500 Bezel, Bezel: stap 13, afbeelding 2 van 3 Disassembling the HP Pavilion tx2500 Bezel, Bezel: stap 13, afbeelding 3 van 3
    • Disconnect the wire from the system board using the plastic opening tool.
    • Disconnect the wire from the optical drive using the plastic opening tool.
    • Gently lift the top cover from the tablet.
  14. Disassembling the HP Pavilion tx2500 Bezel: stap 14, afbeelding 1 van 2 Disassembling the HP Pavilion tx2500 Bezel: stap 14, afbeelding 2 van 2
    • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
    • Disconnect the wire using the plastic opening tool.
  15. Disassembling the HP Pavilion tx2500 Bezel: stap 15, afbeelding 1 van 2 Disassembling the HP Pavilion tx2500 Bezel: stap 15, afbeelding 2 van 2
    • Lift the system board from the tablet.
    • Turn the system board over and lay it flat on a soft surface.
  16. Disassembling the HP Pavilion tx2500 Bezel: stap 16, afbeelding 1 van 1
    • Gently remove the bezel from the system board.
Conclusie
Sarah Naiser
324 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 756
