Ga door naar hoofdinhoud
Disassembling the Ematic Genesis
Wat je nodig hebt
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: stap 1, afbeelding 1 van 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: stap 1, afbeelding 2 van 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: stap 1, afbeelding 3 van 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: stap 2, afbeelding 1 van 3 Disassembling the Ematic Genesis: stap 2, afbeelding 2 van 3 Disassembling the Ematic Genesis: stap 2, afbeelding 3 van 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: stap 3, afbeelding 1 van 1
    • Remove back plate from screen plate and lay both down flat next to each other.
Conclusie
Justin Rohrman
745 Reputatie
6 handleidingen geschreven
Baylor, Team 4-3, Williams Spring 2015 Lid van Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 414
