Onderdelen
Geen onderdelen nodig.
  1. Begin by removing the rubber grip along the handle.
    • Begin by removing the rubber grip along the handle.
  2. Remove the screws from the top to take the metal piece and plastic part off.
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  5. Here is the final result. This gives access to the switch button, chip set, battery and motor.
    • Here is the final result. This gives access to the switch button, chip set, battery and motor.
Conclusie
12 andere personen hebben deze handleiding voltooid.
nathan
1.150 Reputatie
6 handleidingen geschreven
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - Antwoord
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - Antwoord
Thanks…worked well.
Magpie - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 11
Afgelopen 7 Dagen: 77
Afgelopen 30 Dagen: 298
Altijd: 24,148
