Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je iClicker te repareren, gebruik onze reparatiehandleidingen.
  1. Disassembling iClicker Device, Disassembling iClicker Device: stap 1, afbeelding 1 van 1
    • Behold the iclicker in all its interactive and educational beauty.
  2. Disassembling iClicker Device: stap 2, afbeelding 1 van 1
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
  3. Disassembling iClicker Device: stap 3, afbeelding 1 van 2 Disassembling iClicker Device: stap 3, afbeelding 2 van 2
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
  4. Disassembling iClicker Device: stap 4, afbeelding 1 van 2 Disassembling iClicker Device: stap 4, afbeelding 2 van 2
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
  5. Disassembling iClicker Device: stap 5, afbeelding 1 van 1
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
  6. Disassembling iClicker Device: stap 6, afbeelding 1 van 2 Disassembling iClicker Device: stap 6, afbeelding 2 van 2
    • Using a spudger, gently pry the battery connectors from the front panel.
  7. Disassembling iClicker Device: stap 7, afbeelding 1 van 1
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
  8. Disassembling iClicker Device: stap 8, afbeelding 1 van 1
    • The buttons can be easily removed from the front assembly sans spudger.
  9. Disassembling iClicker Device: stap 9, afbeelding 1 van 1
    • Don't lose the small LED cover sitting precariously in the front panel.
  10. Disassembling iClicker Device: stap 10, afbeelding 1 van 1
    • Your iclicker is now disassembled.
1Gids Commentaar
What is an iClicker ?
furbies - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 8,000
