Ga door naar hoofdinhoud
Disassembling Yamaha YPG-225 Faceplate
Wat je nodig hebt
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: stap 1, afbeelding 1 van 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: stap 2, afbeelding 1 van 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: stap 3, afbeelding 1 van 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: stap 4, afbeelding 1 van 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: stap 5, afbeelding 1 van 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: stap 6, afbeelding 1 van 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: stap 7, afbeelding 1 van 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: stap 8, afbeelding 1 van 2 Disassembling Yamaha YPG-225 Faceplate: stap 8, afbeelding 2 van 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Conclusie
Lonnie Bissmeyer
468 Reputatie
4 handleidingen geschreven
Cal Poly, Team 2-62, Propen Fall 2012 Lid van Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 1,680
