Ga door naar hoofdinhoud
Disassembling Xbox 360 E Top Panel
Wat je nodig hebt
  1. Disassembling Xbox 360 E Top Panel, Top Panel: stap 1, afbeelding 1 van 1
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Disassembling Xbox 360 E Top Panel: stap 2, afbeelding 1 van 1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Disassembling Xbox 360 E Top Panel: stap 3, afbeelding 1 van 3 Disassembling Xbox 360 E Top Panel: stap 3, afbeelding 2 van 3 Disassembling Xbox 360 E Top Panel: stap 3, afbeelding 3 van 3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jennifer
2.020 Reputatie
4 handleidingen geschreven
Cal Poly, Team 2-11, Amido Winter 2014 Lid van Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Leden
44 handleidingen geschreven
Één opmerking
I broke my spudger! May I use anything besides that?
Colin2 Schrek - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 27
Altijd: 2,886
