Inleiding
You will need to remove the top body of your Xbox 360 E in order to get inside your Xbox and replace other parts, such as the CD drive or motherboard.
Wat je nodig hebt
Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
Remove the 11 mm screw left of the green wifi-card using the T9 Torx screw bit.
Push the spudger into the crevice between the right grated face and the top body of the Xbox. It's easier to begin away from the vent.
Pull up on the spudger like a lever, keeping it pressed firmly into the crevice.
In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
Orient the Xbox so the bottom body is facing upwards. Make sure you see the rubber feet to know you have the correct side of the device.
Lift the bottom body slightly away from the core at a 45 degree angle.
Remove the five long black 55 mm screws labeled C2-5 and C7 with a T9 Torx screwdriver.
Carefully flip the device and pull off the body by lifting from the metal section that is attached to the plastic exterior.
22 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Thank you for sharing your instructions. I'd just like to ask if dismantelling the Xbox and cleaning out dust and dirt would help with the overheating message problem that I have? I know that there are videos etc on how to redo the solder connection that often leads to this fault, but my soldering skills are a bit "rusty" ! Do you have any other suggestions for this fault?
De - dusting certainly wouldn't hurt.
Wystarczy dac nowa paste termo przewodzącą na procesor
