Ga door naar hoofdinhoud
Disassembling Western Digital Essentials HD LED Light conducting plastic pieces
Wat je nodig hebt
  1. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: stap 1, afbeelding 1 van 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: stap 1, afbeelding 2 van 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, Case: stap 1, afbeelding 3 van 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: stap 2, afbeelding 1 van 2 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: stap 2, afbeelding 2 van 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces, LED Light conducting plastic pieces: stap 3, afbeelding 1 van 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: stap 4, afbeelding 1 van 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: stap 4, afbeelding 2 van 3 Disassembling Western Digital Essentials HD LED Light conducting plastic pieces: stap 4, afbeelding 3 van 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
Conclusie
Gaetan
9.574 Reputatie
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,078
