Ga door naar hoofdinhoud
Disassembling Western Digital Essentials HD Anti-vibration rubber pieces
Wat je nodig hebt
  1. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: stap 1, afbeelding 1 van 3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: stap 1, afbeelding 2 van 3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: stap 1, afbeelding 3 van 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 2, afbeelding 1 van 2 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 2, afbeelding 2 van 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, LED Light conducting plastic pieces: stap 3, afbeelding 1 van 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 4, afbeelding 1 van 3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 4, afbeelding 2 van 3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 4, afbeelding 3 van 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Hard Drive: stap 5, afbeelding 1 van 2 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Hard Drive: stap 5, afbeelding 2 van 2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 6, afbeelding 1 van 2 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 6, afbeelding 2 van 2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: stap 7, afbeelding 1 van 1
    • Remove the rubber piece from the SATA/USB bridge logic board.
Conclusie
Gaetan
9.574 Reputatie
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,555
