Ga door naar hoofdinhoud
Disassembling Western Digital Elements SE HD case and mainboard
Wat je nodig hebt
  1. Disassembling Western Digital Elements SE HD case and mainboard, Opening the case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • The case can be opened easily with a plastic case opening tool. Strong finger nails and an old credit card / plastic card may work too.
  2. Disassembling Western Digital Elements SE HD case and mainboard, Remove marked screws (T5): stap 2, afbeelding 1 van 1
    • The 5 marked screws can be removed with a Torx T5.
  3. Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: stap 3, afbeelding 1 van 2 Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: stap 3, afbeelding 2 van 2
    • Lift the board gently - there is only one small connector connecting the board to the hard disk case (around the yellow market space).
    • On the second image, you can see the board turned over.
    • Further disassembly would damage the disk. I hoped to find a SATA connector within, but maybe someone knows an alternative board with the same connector.
  4. Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: stap 4, afbeelding 1 van 2 Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: stap 4, afbeelding 2 van 2
    • The label on the WD Elements SE case and the labels on the harddisk can be seen here. I censored serial numbers, the WWID and the barcodes.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bastli
256 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 111
Altijd: 1,645
