Ga door naar hoofdinhoud
Visioneer OneTouch 7400 USB Outer Case Replacement
Wat je nodig hebt
  1. Visioneer OneTouch 7400 USB Outer Case Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Outer Case Replacement: stap 2, afbeelding 1 van 2 Visioneer OneTouch 7400 USB Outer Case Replacement: stap 2, afbeelding 2 van 2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Outer Case Replacement: stap 3, afbeelding 1 van 3 Visioneer OneTouch 7400 USB Outer Case Replacement: stap 3, afbeelding 2 van 3 Visioneer OneTouch 7400 USB Outer Case Replacement: stap 3, afbeelding 3 van 3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Outer Case Replacement: stap 4, afbeelding 1 van 1
    • Separate the two casement pieces.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jena
608 Reputatie
6 handleidingen geschreven
University of Maine, Team 1-13, Diaz Fall 2013 Lid van University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 270
