Ga door naar hoofdinhoud
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
Wat je nodig hebt
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: stap 1, afbeelding 1 van 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 2, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 2, afbeelding 2 van 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 3, afbeelding 1 van 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 3, afbeelding 2 van 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 4, afbeelding 1 van 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 5, afbeelding 1 van 1
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 6, afbeelding 1 van 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: stap 7, afbeelding 1 van 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
Conclusie
Daniel Kresge
385 Reputatie
4 handleidingen geschreven
USF Tampa, Team 8-3, Eyestone Fall 2015 Lid van USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Leden
17 handleidingen geschreven
Één opmerking
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 35
Altijd: 2,015
