Inleiding
This guide shows how to remove the tire from the wheel of a Trek 820 bicycle. When diagnosing a tire that does not stay inflated, removing the tire allows for easier and more thorough inspection of the inner tube, sealing surfaces, and other potential damage. No special skills or tools are required, although purpose-made bicycle tire removal tools are available that may make the job easier. This guide will show how to remove the tire without any special tools.
Wat je nodig hebt
Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
For tire reinstallation, simply follow these steps in reverse order.
Één opmerking
Be very careful using a screwdriver to unseat the tire as it is very likely you will pinch and thus ruin the tube. Better to buy several tire levers at any bike shop - they are inexpensive and made for this job.
