Ga door naar hoofdinhoud
Disassembling Toshiba Satellite C55-A5285/C55-A1J2
Wat je nodig hebt
  1. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing battery and backpanel: stap 1, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing battery and backpanel: stap 1, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing battery and backpanel: stap 1, afbeelding 3 van 3
    • First of all remove the battery.
    • like always : draw a map of the laptop and paste/draw where all the screws come from or use a magentic project map.
    • remove the bottom plate of the ram and HDD.
  2. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing ram and hdd: stap 2, afbeelding 1 van 2 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing ram and hdd: stap 2, afbeelding 2 van 2
    • now remove the hdd screw ( red circkle)
    • lift up the HDD
    • remove the ram by clicking the levars to the outside
  3. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing the dvd bay: stap 3, afbeelding 1 van 2 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing the dvd bay: stap 3, afbeelding 2 van 2
    • remove the screw , and use a spudger to remove the dvd bay. ( slide it out)
  4. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing keyboard: stap 4, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing keyboard: stap 4, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing keyboard: stap 4, afbeelding 3 van 3
    • remove the screw of the keyboard, orange circkle
    • turn the laptop again and remove the keyboard.
    • use a isesamo to click the keyboard off the laptop. the "click levars"( 6 of them) are under number 0 , between left arrow and ctrl, alt gr , space bar, windows button and alt and ctrl(left)
    • do it very gently , you can break the keyboard or you can break some buttons off the keyboard.
    • after clicking the keyboard loose, lift the lid of the connector socket up and remove the flex cable. you can see a picture in step 6.
  5. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws and connectors: stap 5, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws and connectors: stap 5, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws and connectors: stap 5, afbeelding 3 van 3
    • now you will see 2 connectors and 7 screws under the keyboard.
    • If you don't know how to remove the connectors safely see the next step.
    • remove the screws and gently remove the 2 connectors from the connectors. like always do it gently.
    • the orange circkles are the screws to remove the mainboard in a later step
    • the red squares are the connectors of the mouse pad and powerboard
    • the blue square is the connector from the keyboard.
  6. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing connectors: stap 6, afbeelding 1 van 2 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing connectors: stap 6, afbeelding 2 van 2
    • use a spudger or little flathead screwdriver to open the lid of the connectors.
  7. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws of case: stap 7, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws of case: stap 7, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws of case: stap 7, afbeelding 3 van 3
    • again : draw a map of the laptop , so you remeber where all the screws come from. Or use a magnetic project map.
    • first screws : 3 screws in the HDD compartiment.
    • screws at the side , also see the next step for the rest of the screws.
  8. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws and case step 2: stap 8, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws and case step 2: stap 8, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing screws and case step 2: stap 8, afbeelding 3 van 3
    • remove the last screws
    • then : slide your spudger or isesamo between the bottom plate and upper plate to remove the case. you will hear clicks. be gently while sliding
  9. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, opening the laptop: stap 9, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, opening the laptop: stap 9, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, opening the laptop: stap 9, afbeelding 3 van 3
    • gently remove the plate.
    • after opening you'll see the mainboard or like we call it here in Belgium : the motherboard.
  10. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing/ cleaning fan and cooling pads: stap 10, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing/ cleaning fan and cooling pads: stap 10, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, removing/ cleaning fan and cooling pads: stap 10, afbeelding 3 van 3
    • in this step we will show you how to remove the fan and the cooling tubes and pads for cleaning or renewing.
    • there are 8 screws and 1 connector
    • remove the screws ( 1 screw is not on the pictures, you ll find it at the bottom of the fan) but unscrew them simultaneous.
    • remove the connector ( see picture 2 ) using an IC extractor
    • remove the cooling tubes and fan.
    • clean the pads using isopropyl alcohol. you will see pieces (remnants ?) of old thermal paste.
    • if the fan itself is broken , you can replace this by removing the very tiny screws. and remove the black tape.
  11. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, cooling pads/ fan and renewing thermal paste: stap 11, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, cooling pads/ fan and renewing thermal paste: stap 11, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, cooling pads/ fan and renewing thermal paste: stap 11, afbeelding 3 van 3
    • clean CPU and pads with isopropyl alcohol. But, like you know ,be carefull with this.
    • use gloves
    • you can also renew /upgrade the cpu, just use a flathead screwdriver to open the cpu socket.
  12. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, thermal paste: stap 12, afbeelding 1 van 2 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, thermal paste: stap 12, afbeelding 2 van 2
    • use gloves , cause thermal paste is very toxic.
    • one drop is enough on the CPU , and a little drop on the graphic chip.
  13. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, mainboard: stap 13, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, mainboard: stap 13, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, mainboard: stap 13, afbeelding 3 van 3
    • removing or replacing the Mainboard :
    • first remove the LCD connector: do it very gently, there are a lot of tiny thin wires, they are very breakable. you see this in picture 2, if you have to replace the whole screen, i don't have pictures of this in this guide, but we have other guides that show you how to or you can find these here at ifixit.com
    • remove the screw you see in picture 3
  14. Disassembling Toshiba Satellite C55-A5285/C55-A1J2, mainboard step 2 DC JACK/ WIFI/MOUSEPAD: stap 14, afbeelding 1 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, mainboard step 2 DC JACK/ WIFI/MOUSEPAD: stap 14, afbeelding 2 van 3 Disassembling Toshiba Satellite C55-A5285/C55-A1J2, mainboard step 2 DC JACK/ WIFI/MOUSEPAD: stap 14, afbeelding 3 van 3
    • in these 3 pictures: dc jack in picture one, + the connector, and the usb pcb. if you have to replace the dc jack, be gently with the connector.
    • second picture : wifi module. always remember the color code ( black and white)
    • third picture : mousepad and screws.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Kevin D
7.294 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 19,977
