Ga door naar hoofdinhoud
Disassembling Toshiba A1304T Front Cover
Wat je nodig hebt
  1. Disassembling Toshiba A1304T Front Cover, Front Cover: stap 1, afbeelding 1 van 1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Disassembling Toshiba A1304T Front Cover: stap 2, afbeelding 1 van 2 Disassembling Toshiba A1304T Front Cover: stap 2, afbeelding 2 van 2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Disassembling Toshiba A1304T Front Cover: stap 3, afbeelding 1 van 2 Disassembling Toshiba A1304T Front Cover: stap 3, afbeelding 2 van 2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
Conclusie
Christopher
90 Reputatie
8 handleidingen geschreven
Cal Poly, Team 16-6, Maness Spring 2010 Lid van Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,132
