Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Make sure your workplace is ESD secured
An ESD workmat and a ESD wristlet will get you far
Don't continue if your knowledge on ESD is lacking !
Purple screws dedicated to the keyboard, none of them should need removal
The bottom three screws has a rubber head upon them. Make sure you remove them carefully(some kind of adhesive on them).
Note that the screws will not jump out easily even though they are loose,
Remove the purple cable(battery). Might not be nessesary if you followed step 1 correctly
The blue indicates the M.2. SSD 42mm (2242). 256GB worked perfectly for me. Only exists if you have a version with separate cache.
Green box indicates the HDD
Red: RAM slot SO-DIMM DDR3 (only one) 8GB
7 andere personen hebben deze handleiding voltooid.
Één commentaar
Since older Lenovo are identical to open just look for an older model in case you have a brand new Lenovo and the hardware manual is not free availabe for download (very unusual).
