Ga door naar hoofdinhoud
Disassembling Speak And Spell Case
Wat je nodig hebt
  1. Disassembling Speak And Spell Case, Case: stap 1, afbeelding 1 van 2 Disassembling Speak And Spell Case, Case: stap 1, afbeelding 2 van 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: stap 2, afbeelding 1 van 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Conclusie
bushing
10.286 Reputatie
13 handleidingen geschreven
Één opmerking
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 5,009
