Ga door naar hoofdinhoud
Disassembling Speak And Spell Case
Wat je nodig hebt
  1. Disassembling Speak And Spell Case, Case: stap 1, afbeelding 1 van 2 Disassembling Speak And Spell Case, Case: stap 1, afbeelding 2 van 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: stap 2, afbeelding 1 van 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
bushing
10.463 Reputatie
13 handleidingen geschreven
1Gids Commentaar
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 31
Altijd: 5,368
