Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
Bijna klaar!
Conclusie
