Ga door naar hoofdinhoud
Disassembling Sony Ericsson W580i Back Cover
Wat je nodig hebt
  1. Disassembling Sony Ericsson W580i Back Cover, Battery: stap 1, afbeelding 1 van 3 Disassembling Sony Ericsson W580i Back Cover, Battery: stap 1, afbeelding 2 van 3 Disassembling Sony Ericsson W580i Back Cover, Battery: stap 1, afbeelding 3 van 3
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Disassembling Sony Ericsson W580i Back Cover: stap 2, afbeelding 1 van 1
    • Lift the battery out from the bottom edge.
  3. Disassembling Sony Ericsson W580i Back Cover, Back Cover: stap 3, afbeelding 1 van 1
    • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
    • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
    • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
  4. Disassembling Sony Ericsson W580i Back Cover: stap 4, afbeelding 1 van 3 Disassembling Sony Ericsson W580i Back Cover: stap 4, afbeelding 2 van 3 Disassembling Sony Ericsson W580i Back Cover: stap 4, afbeelding 3 van 3
    • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
    • Pull the back cover away from the phone.
    • Remove the power button if it has not already come off.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Cherie
220 Reputatie
2 handleidingen geschreven
Cal Poly, Team 5-31, Amido Fall 2011 Lid van Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 30
Altijd: 8,747
