Ga door naar hoofdinhoud
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
Wat je nodig hebt
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: stap 1, afbeelding 1 van 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 2, afbeelding 1 van 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 2, afbeelding 2 van 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 3, afbeelding 1 van 1
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 4, afbeelding 1 van 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 4, afbeelding 2 van 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 5, afbeelding 1 van 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 5, afbeelding 2 van 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 6, afbeelding 1 van 1
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 7, afbeelding 1 van 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 7, afbeelding 2 van 2
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 8, afbeelding 1 van 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 8, afbeelding 2 van 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 9, afbeelding 1 van 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 9, afbeelding 2 van 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 9, afbeelding 3 van 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 10, afbeelding 1 van 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 10, afbeelding 2 van 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: stap 10, afbeelding 3 van 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
Conclusie
Christine Becker
101 Reputatie
1 Handleiding geschreven
University of Maine, Team 1-13, Diaz Fall 2013 Lid van University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 3,556
