Ga door naar hoofdinhoud
Disassembling Sony Cyber-shot DSC-W5 Back Cover
Wat je nodig hebt
  1. Disassembling Sony Cyber-shot DSC-W5 Back Cover, Back Cover: stap 1, afbeelding 1 van 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Disassembling Sony Cyber-shot DSC-W5 Back Cover: stap 2, afbeelding 1 van 2 Disassembling Sony Cyber-shot DSC-W5 Back Cover: stap 2, afbeelding 2 van 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Disassembling Sony Cyber-shot DSC-W5 Back Cover: stap 3, afbeelding 1 van 2 Disassembling Sony Cyber-shot DSC-W5 Back Cover: stap 3, afbeelding 2 van 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
Conclusie
Thomas
133 Reputatie
6 handleidingen geschreven
Cal Poly, Team 15-50, Garner Spring 2010 Lid van Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 5,556
