Ga door naar hoofdinhoud
Disassembling Sirius Stiletto 100 Front Cover
Wat je nodig hebt
  1. Disassembling Sirius Stiletto 100 Front Cover, Front Cover: stap 1, afbeelding 1 van 2 Disassembling Sirius Stiletto 100 Front Cover, Front Cover: stap 1, afbeelding 2 van 2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Front Cover: stap 2, afbeelding 1 van 2 Disassembling Sirius Stiletto 100 Front Cover: stap 2, afbeelding 2 van 2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Front Cover: stap 3, afbeelding 1 van 3 Disassembling Sirius Stiletto 100 Front Cover: stap 3, afbeelding 2 van 3 Disassembling Sirius Stiletto 100 Front Cover: stap 3, afbeelding 3 van 3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
Conclusie
Trey
80 Reputatie
2 handleidingen geschreven
Clemson, Team 2-1, Benson Spring 2012 Lid van Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,586
