Ga door naar hoofdinhoud
Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing
Wat je nodig hebt
  1. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing, Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 1, afbeelding 1 van 1
    • Camera lens are delicate and intricate. Be careful with the disassembly and work slowly.
    • Take the lens away from camera
    • DO NOT FORGET: THAT YOU ARE DOING ALL ON YOUR OWN RESPONSIBILITY
  2. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 2, afbeelding 1 van 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 2, afbeelding 2 van 2
    • Unscrew the top part and detach it.
    • Unjoin cables. Be careful; they're delicate, and easily torn.
    • Try to avoid touching sensitive electronic components.
    • Unfasten the screws that hold the circuit board in place, and separate it from the rest of the lens assembly.
  3. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 3, afbeelding 1 van 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 3, afbeelding 2 van 2
    • Take away zoom rubber and you will find srews
  4. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 4, afbeelding 1 van 2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 4, afbeelding 2 van 2
    • Keep unscrewing and removing the parts until you reach what you need to fix.
    • Zoom bearing can be taken away by unscrewing its srews.
  5. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: stap 5, afbeelding 1 van 1
    • Here is one of the parts which was broken, so I go to camera repair shop, and bought that parts. As this was not the only part broken, I had to leave for additional repair.
    • When you finish you can put all back together
Conclusie
6 andere personen hebben deze handleiding voltooid.
Rimvydas
718 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 54
Altijd: 29,873
