Ga door naar hoofdinhoud
Disassembling Samsung Gravity SGH-T459 Keypad
Wat je nodig hebt
  1. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Back Cover: stap 1, afbeelding 1 van 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Battery: stap 2, afbeelding 1 van 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: stap 3, afbeelding 1 van 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: stap 3, afbeelding 2 van 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: stap 3, afbeelding 3 van 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: stap 4, afbeelding 1 van 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: stap 4, afbeelding 2 van 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Gently remove the two button contacts with your fingers.
    • Use a plastic prying tool to pry the keypad away from the circuit board.
    • Use tweezers to gently remove the keypad.
Conclusie
William Glatz
1 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 757
