Ga door naar hoofdinhoud
Inleiding
This guide will allow users of the Samsung Galaxy S Blaze to understand how to take the phone apart. The guide will make future repairs easier to accomplish. The disassembly of the phone is an easy process with no surprises. You will need to be careful with the screws that are inside the device, the screws will strip easily. To properly disassemble the phone you will need a Phillips Head screw driver size 00 and a flat wedge opening device.
Onderdelen
Geen onderdelen opgegeven.
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Whole Device: stap 1, afbeelding 1 van 1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: stap 2, afbeelding 1 van 1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: stap 3, afbeelding 1 van 2 Disassembling Samsung Galaxy S Blaze Whole Device: stap 3, afbeelding 2 van 2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: stap 4, afbeelding 1 van 1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: stap 5, afbeelding 1 van 1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: stap 6, afbeelding 1 van 1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: stap 7, afbeelding 1 van 1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: stap 8, afbeelding 1 van 3 Disassembling Samsung Galaxy S Blaze Whole Device: stap 8, afbeelding 2 van 3 Disassembling Samsung Galaxy S Blaze Whole Device: stap 8, afbeelding 3 van 3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: stap 9, afbeelding 1 van 1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: stap 10, afbeelding 1 van 1
    • All of the parts are seen here.
Conclusie
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Jake Best
261 Reputatie
2 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 610
