Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Remove 5.8mm Phillips #1 screw from the side button panel.
Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
Pry along the seam on the top side near the buttons with a spudger.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
