Ga door naar hoofdinhoud
Disassembling Qualcomm QCP-2760 Rear Backing
Wat je nodig hebt
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: stap 1, afbeelding 1 van 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: stap 2, afbeelding 1 van 2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: stap 2, afbeelding 2 van 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
Conclusie
Xavier
313 Reputatie
3 handleidingen geschreven
Ohio State, Team 1-4, Buehl Fall 2014 Lid van Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 215
