Ga door naar hoofdinhoud
Disassembling ProtoArc EM01 NL
Wat je nodig hebt
    1. Disassembling ProtoArc EM01 NL, Remove Rocker Plate: stap 1, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Remove Rocker Plate: stap 1, afbeelding 2 van 2
      • Push the pins inward, ONE side at a time, then lift the side from the bottom of the main body, to free it from socket. Then take care of the other side.
      • The pins
      • The socket
      • Be aware, there are 2 strong magnets.
      • This is the most difficult part. Take your time.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling ProtoArc EM01 NL, Open Main Body: stap 2, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Open Main Body: stap 2, afbeelding 2 van 2
      • Remove the track ball (THE ball itself)
      • Remove 6 self-tap screws. The one pointed by an arrow needs a long thin philip head screw driver
      • Apply a little bit prying force bear the ball socket, to open the bottom.
      • Not so fast! Watch out for the FPC! Read next step first!
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling ProtoArc EM01 NL, Unplug the FPC: stap 3, afbeelding 1 van 1
      • Unlatch the FPC connector by:
      • Push the black plastic latch up. Using tweezers.
      • Pull out the top cover FPC.
      • If possible, unplug the battery first.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling ProtoArc EM01 NL, Open the Top Case: stap 4, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Open the Top Case: stap 4, afbeelding 2 van 2
      • Now separate top and bottom case.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling ProtoArc EM01 NL, Remove the Ring: stap 5, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Remove the Ring: stap 5, afbeelding 2 van 2
      • Remove the ring from ball socket
      • There's a notch and a pair of keys. Should align them when assembling back.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling ProtoArc EM01 NL, Button Daughterboard: stap 6, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Button Daughterboard: stap 6, afbeelding 2 van 2
      • Unplug the battery, as early as possible!!
      • Remove 1 self-tap screw
      • Lift the tiny PCB witth 2 buttons
      Vraag FixBot
      Voeg opmerking toe
    7. Disassembling ProtoArc EM01 NL, Tracking sensor (Optional): stap 7, afbeelding 1 van 1
      • Same type FPC connector. Handle it as before. But, there's a drop of glue, removing it might damage the connector and/or the cable. Skip this if not intent to replace the tracking sensor.
      Vraag FixBot
      Voeg opmerking toe
    8. Disassembling ProtoArc EM01 NL, Main PCB with Sensor: stap 8, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Main PCB with Sensor: stap 8, afbeelding 2 van 2
      • To remove battery, remove 2 screws. (optional)
      • Remove 4 screws for the PCB
      • Remove 2 screws for the sensor
      • Lift main PCB and the sensor module (ball socket) off the bottom case.
      Vraag FixBot
      Voeg opmerking toe
    9. Disassembling ProtoArc EM01 NL, Type-C Module: stap 9, afbeelding 1 van 2 Disassembling ProtoArc EM01 NL, Type-C Module: stap 9, afbeelding 2 van 2
      • Noticed the 4-pin socket? There is a 4-pin pinheader under main PCB mating with it. should plug them back together while reassembling. Sorry for the shallow DOF, shot really close up and under poor lighting.
      • Remove 2 screws. Then remove the type-C module.
      Vraag FixBot
      Voeg opmerking toe
    10. Disassembling ProtoArc EM01 NL, The Wheel: stap 10, afbeelding 1 van 1
      • Remove the wheel from rotation encoder
      Vraag FixBot
      Voeg opmerking toe
    11. Disassembling ProtoArc EM01 NL, Replace the Button Switch: stap 11, afbeelding 1 van 3 Disassembling ProtoArc EM01 NL, Replace the Button Switch: stap 11, afbeelding 2 van 3 Disassembling ProtoArc EM01 NL, Replace the Button Switch: stap 11, afbeelding 3 van 3
      • Possibly exactly why you need this guide for.
      • Original switch is silent 2-pin square type. It's totally interchangable with common 3-pin mouse switches (Omron D2F type).
      Vraag FixBot
      Voeg opmerking toe
    12. Disassembling ProtoArc EM01 NL, More Detail of the Switch Comparison: stap 12, afbeelding 1 van 1
      • See? same hight. Also same pin pitch.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Terrance
7.063 Reputatie
19 handleidingen geschreven
1Gids Commentaar
Nice guide! I wish we had more information about the encoder so we could replace it. Do you know the exact size to buy?
Paulo César - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 182
Altijd: 1,097
