Ga door naar hoofdinhoud
Disassembling Polaroid a520 Logic Board
Wat je nodig hebt
  1. Disassembling Polaroid a520 Logic Board, Battery: stap 1, afbeelding 1 van 2 Disassembling Polaroid a520 Logic Board, Battery: stap 1, afbeelding 2 van 2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Disassembling Polaroid a520 Logic Board: stap 2, afbeelding 1 van 1
    • Remove the batteries from the camera.
  3. Disassembling Polaroid a520 Logic Board, Casing: stap 3, afbeelding 1 van 1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Disassembling Polaroid a520 Logic Board: stap 4, afbeelding 1 van 1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Disassembling Polaroid a520 Logic Board, LCD Screen: stap 5, afbeelding 1 van 1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Disassembling Polaroid a520 Logic Board: stap 6, afbeelding 1 van 1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  7. Disassembling Polaroid a520 Logic Board, Logic Board: stap 7, afbeelding 1 van 1
    • Unscrew and remove the four (6 mm) screws on the inside casing.
  8. Disassembling Polaroid a520 Logic Board: stap 8, afbeelding 1 van 1
    • Pull the inner casing off of the camera.
  9. Disassembling Polaroid a520 Logic Board: stap 9, afbeelding 1 van 1
    • Unscrew and remove the four (4mm) screws from the logic board.
  10. Disassembling Polaroid a520 Logic Board: stap 10, afbeelding 1 van 1
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
Conclusie
Dani
21 Reputatie
7 handleidingen geschreven
Cal Poly, Team 3-3, Johann Summer 2010 Lid van Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 914
