Ga door naar hoofdinhoud
Inleiding
This guide will show you how to remove the main camera lens assembly from the camera's frame.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the following screws: Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Remove the two indicated screws on the bottom of the camera:
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Carefully pull the back of casing away from the front. Carefully pull the back of casing away from the front.
    • Carefully pull the back of casing away from the front.
  4. After removing the back cover, several things must be removed. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled ā€œPC/AVā€ and ā€œDC IN 4.5Vā€. Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled ā€œPC/AVā€ and ā€œDC IN 4.5Vā€.
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled ā€œPC/AVā€ and ā€œDC IN 4.5Vā€.
  5. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off. To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. On the front of the camera, in battery case, remove screws indicated: Two black 2.05mm Phillips #00 screws
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Flip the camera over to the backside and remove screws indicated: The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in red is a shorter black 2.00mm Phillips #00 screw
  8. Pull the cover plate off for the two power cord jacks.
    • Pull the cover plate off for the two power cord jacks.
  9. Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder. Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder. Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Remove the orange tape on top of the SD cardholder.
    • Remove the orange tape on top of the SD cardholder.
  11. Open the battery cover and lift plastic piece off. Open the battery cover and lift plastic piece off. Open the battery cover and lift plastic piece off.
    • Open the battery cover and lift plastic piece off.
  12. Remove tape on left side of camera.
    • Remove tape on left side of camera.
  13. Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
    • Remove the indicated 2.40mm Phillips #00 screw to release top left LCD bracket.
  14. Remove top left LCD bracket.
    • Remove top left LCD bracket.
    • This is a small piece, be careful not to lose it.
  15. Push down bottom left LCD bracket to release the LCD from grip. Push down bottom left LCD bracket to release the LCD from grip.
    • Push down bottom left LCD bracket to release the LCD from grip.
  16. Gently lift up LCD screen.
    • Gently lift up LCD screen.
  17. Slowly pull LCD screen to the left to remove it from the other grips. BEWARE: The LCD screen is attached to the logic board by two wires at the bottom. BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
    • Slowly pull LCD screen to the left to remove it from the other grips.
    • BEWARE: The LCD screen is attached to the logic board by two wires at the bottom.
  18. Lift up tape slightly on both sides of speaker. Lift up tape slightly on both sides of speaker. Lift up tape slightly on both sides of speaker.
    • Lift up tape slightly on both sides of speaker.
  19. Use the pointed end of a spudger to lift up brackets. Lift speaker cover out. Lift speaker cover out.
    • Use the pointed end of a spudger to lift up brackets.
    • Lift speaker cover out.
  20. Remove speaker cover.
    • Remove speaker cover.
  21. Turn camera to front. Carefully peel off orange wire tape. The tape is glued to the surface indicated.
    • Turn camera to front.
    • Carefully peel off orange wire tape. The tape is glued to the surface indicated.
    • Lift speaker from holder.
  22. Use a wedge to lift up the wire tape flap. Use a wedge to lift up the wire tape flap.
    • Use a wedge to lift up the wire tape flap.
  23. Insert the point of a spudger underneath the wire shown. Insert the point of a spudger underneath the wire shown. Insert the point of a spudger underneath the wire shown.
    • Insert the point of a spudger underneath the wire shown.
  24. Carefully lift the wire out of the crevasses. Carefully lift the wire out of the crevasses.
    • Carefully lift the wire out of the crevasses.
  25. Slowly bend the speaker's wire tape away from the lens assembly.  Avoid creasing the tape.
    • Slowly bend the speaker's wire tape away from the lens assembly. Avoid creasing the tape.
  26. Remove indicated screws: Three Black 3.80mm Phillips #00 screws. Three Black 3.80mm Phillips #00 screws.
    • Remove indicated screws:
    • Three Black 3.80mm Phillips #00 screws.
  27. Remove the indicated black 3.40mm Phillips #00 screw on the bottom of the camera. Remove copper leads.
    • Remove the indicated black 3.40mm Phillips #00 screw on the bottom of the camera.
    • Remove copper leads.
  28. Unscrew the indicated 3.80mm Phillips #00 screw on the back of the camera. Remove screw and bracket. Remove screw and bracket.
    • Unscrew the indicated 3.80mm Phillips #00 screw on the back of the camera.
    • Remove screw and bracket.
  29. Turn the camera over to the front.
    • Turn the camera over to the front.
    • In the following step, you will undo the indicated pegs. PROCEED TO THE NEXT STEP.
  30. Carefully holding the camera, grab the corresponding two points. Carefully twist the lens assembly away from you. You will be turning your hand clockwise. Pull lens assembly out.
    • Carefully holding the camera, grab the corresponding two points.
    • Carefully twist the lens assembly away from you. You will be turning your hand clockwise.
    • Pull lens assembly out.
    • The lens assembly is attached to the logic board by wire tape.
Conclusie
Bassem Tossoun
201 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-29, Regan Winter 2011 Lid van Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 Leden
10 handleidingen geschreven
2 Opmerkingen
Do you have this disassembly steps for the S12?
ThoH - Antwoord
Lens will Not focuscorrectly
ThoH - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,812
