Ga door naar hoofdinhoud
Disassembling Pentax K200D Front Cover
Wat je nodig hebt
  1. Disassembling Pentax K200D Front Cover, Preparation: stap 1, afbeelding 1 van 1
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: stap 2, afbeelding 1 van 1
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: stap 3, afbeelding 1 van 1
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: stap 4, afbeelding 1 van 1
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Rick Nelson
706 Reputatie
1 Handleiding geschreven
Master Techs Lid van Master Techs
Community
314 Leden
1.322 handleidingen geschreven
Één opmerking
How do l clean the prisum…
brett_lorking - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 6,049
