Ga door naar hoofdinhoud
Disassembling Panasonic GU87 Minor-LCD
Wat je nodig hebt
  1. Disassembling Panasonic GU87 Minor-LCD, LCD Cover removal: stap 1, afbeelding 1 van 1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Minor-LCD: stap 2, afbeelding 1 van 1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Minor-LCD, LCD: stap 3, afbeelding 1 van 1
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Minor-LCD: stap 4, afbeelding 1 van 1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
Conclusie
Van
7 Reputatie
8 handleidingen geschreven
Cal Poly, Team 2-10, Johann Summer 2010 Lid van Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 1,334
