Ga door naar hoofdinhoud
Disassembling Panasonic GU87 Main Board removal
Wat je nodig hebt
  1. Disassembling Panasonic GU87 Main Board removal, Battery: stap 1, afbeelding 1 van 1
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Main Board removal: stap 2, afbeelding 1 van 1
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Back cover: stap 3, afbeelding 1 van 1
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Main Board removal: stap 4, afbeelding 1 van 1
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Main Board removal: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Main Board removal: stap 6, afbeelding 1 van 1
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
  7. Disassembling Panasonic GU87 Main Board removal, Disassembling Panasonic GU87 Main Board removal: stap 7, afbeelding 1 van 1
    • Lift the main board over.
  8. Disassembling Panasonic GU87 Main Board removal: stap 8, afbeelding 1 van 1
    • Pry the connector with finger nails.
Conclusie
Van
7 Reputatie
8 handleidingen geschreven
Cal Poly, Team 2-10, Johann Summer 2010 Lid van Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,743
