Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
  1. Remove the four rubber screw covers from encircled locations.
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  5. Use fingernails to pry off minor LCD mount, as shown.
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  6. Unlock the LCD main board connectors shown in red boxes on the picture .
    • Unlock the LCD main board connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  7. Place finger nails on the connector tab as shown.
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  8. Pull/pivot the LCD main board as shown in order to remove.
    • Pull/pivot the LCD main board as shown in order to remove.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Van
7 Reputatie
8 handleidingen geschreven
Cal Poly, Team 2-10, Johann Summer 2010 Lid van Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Leden
20 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,739
