Ga door naar hoofdinhoud
Disassembling Olympus Stylus 725 SW Side Panels
Wat je nodig hebt
  1. Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 1 van 2 Disassembling Olympus Stylus 725 SW Side Panels, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 2 van 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: stap 2, afbeelding 1 van 3 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: stap 2, afbeelding 2 van 3 Disassembling Olympus Stylus 725 SW Side Panels, Front Panel: stap 2, afbeelding 3 van 3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  3. Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: stap 3, afbeelding 1 van 3 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: stap 3, afbeelding 2 van 3 Disassembling Olympus Stylus 725 SW Side Panels, Side Panels: stap 3, afbeelding 3 van 3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  4. Disassembling Olympus Stylus 725 SW Side Panels: stap 4, afbeelding 1 van 3 Disassembling Olympus Stylus 725 SW Side Panels: stap 4, afbeelding 2 van 3 Disassembling Olympus Stylus 725 SW Side Panels: stap 4, afbeelding 3 van 3
    • After removing all four of the screws, pry the side covers off of the camera.
Conclusie
Bobby Hodges
49 Reputatie
6 handleidingen geschreven
Cal Poly, Team 33-71, Johann Spring 2010 Lid van Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 2,830
