Ga door naar hoofdinhoud
Disassembling Olympus Stylus 725 SW Back Panel
Wat je nodig hebt
  1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 1 van 2 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: stap 1, afbeelding 2 van 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: stap 2, afbeelding 1 van 3 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: stap 2, afbeelding 2 van 3 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: stap 2, afbeelding 3 van 3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Disassembling Olympus Stylus 725 SW Back Panel: stap 3, afbeelding 1 van 2 Disassembling Olympus Stylus 725 SW Back Panel: stap 3, afbeelding 2 van 2
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
Conclusie
Bobby Hodges
49 Reputatie
6 handleidingen geschreven
Cal Poly, Team 33-71, Johann Spring 2010 Lid van Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 4,314
