Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws) Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
    • Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
    Put a notice on here that the screws are very small and are easy to misplace while disassembling device. Also, while disassembling the device there was only one screw present, where the guide suggested there were three.
    Curtis Reedy - Antwoord
    Before beginning, put a note that the camera should be turned off before proceeding.
    Add a note at the beginning of the guide that there are a large number of small screws that should be separated as the steps are completed.
    There's a capacitor .....watch out for it in every step.
    BILL BOYD - Antwoord
  2. Remove the right side panel by pulling off the large silver piece.
    • Remove the right side panel by pulling off the large silver piece.
    There is no reference to removing screws from the right side panel, where it is necessary to remove 2 screws to do so.
  3. Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws) Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
    • Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
  4. PC Laptop batterijen
    Een snelle fix voor een grote boost.
    Nu winkelen
    Nu winkelen
  5. Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
  6. Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
    • Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
  7. Remove 3 screws from the front of the camera using a #00 screwdriver. Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side) Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
    • Remove 3 screws from the front of the camera using a #00 screwdriver.
    • Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
    Wrong point of focus for the second picture. What should be in focus is very blurry.
  8. Using a plastic spudger, lift up the black clips. Still using the plastic spudger, detach the gold connector strip and white connector strip. Using both hands, pull the camera apart into two pieces.
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
    There were multiple gold strips, so the one that needs to be pulled should be highlited in the picture.
    in step seven pull up the black bar of the ZIF connectors before pulling out the white or gold ribbons
Conclusie
Max McIntyre
511 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-4, Forte Winter 2011 Lid van Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Leden
6 handleidingen geschreven
Één commentaar
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 5
Altijd: 2,630
