Ga door naar hoofdinhoud
Disassembling Olympus FE-170 Casing
Wat je nodig hebt
  1. Disassembling Olympus FE-170 Casing, Casing: stap 1, afbeelding 1 van 2 Disassembling Olympus FE-170 Casing, Casing: stap 1, afbeelding 2 van 2
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Disassembling Olympus FE-170 Casing: stap 2, afbeelding 1 van 2 Disassembling Olympus FE-170 Casing: stap 2, afbeelding 2 van 2
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Disassembling Olympus FE-170 Casing: stap 3, afbeelding 1 van 2 Disassembling Olympus FE-170 Casing: stap 3, afbeelding 2 van 2
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Disassembling Olympus FE-170 Casing: stap 4, afbeelding 1 van 1
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Disassembling Olympus FE-170 Casing: stap 5, afbeelding 1 van 1
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Disassembling Olympus FE-170 Casing: stap 6, afbeelding 1 van 2 Disassembling Olympus FE-170 Casing: stap 6, afbeelding 2 van 2
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Disassembling Olympus FE-170 Casing: stap 7, afbeelding 1 van 2 Disassembling Olympus FE-170 Casing: stap 7, afbeelding 2 van 2
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Disassembling Olympus FE-170 Casing: stap 8, afbeelding 1 van 2 Disassembling Olympus FE-170 Casing: stap 8, afbeelding 2 van 2
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
Conclusie
CCrane
201 Reputatie
2 handleidingen geschreven
Baylor, Team 6-4, Shaver Spring 2015 Lid van Baylor, Team 6-4, Shaver Spring 2015
BU-SHAVER-S15S6G4
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 640
