Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Flip over the turntable and remove the nine screws on the outer edges. Flip over the turntable and remove the nine screws on the outer edges.
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Remove the back cover by pulling it apart.
    • Remove the back cover by pulling it apart.
  3. De essentiële toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  4. Locate the largest circuit board inside the device.
    • Locate the largest circuit board inside the device.
  5. Locate the wires that are plugged into the side of the circuit board.
    • Locate the wires that are plugged into the side of the circuit board.
  6. Gently pull out the wires plugged into the circuit board. Gently pull out the wires plugged into the circuit board.
    • Gently pull out the wires plugged into the circuit board.
  7. Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board. Note that these wires are soldered onto the circuit, indicated by the red markers.
    • Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board.
    • Note that these wires are soldered onto the circuit, indicated by the red markers.
    • To completely remove the circuit board these wires must be removed.
Conclusie
Sukhjinder
11 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-14, Regan Fall 2011 Lid van Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,249
